Hello Tom.
I am building lathe with Kflop+Kstep
boards and I have some questions regarding spindle closed
loop control setup.
Spindle motor is 220V DC motor. I have
designed controller to drive this motor, and it works
fine.
DC motor controller drives thyristor
bridge, and voltage applied to motor varies depending
triac phase firing angle. I have connected controller to
Kflop step dir channel. Each 1/100 sec controller counts
steps, calculates commanded velocity and transfer it to
voltage applied to motor drive. Commanded velocity is
proportional to output voltage. I had to use some math
approximation cause of 8 bit controller, but velocity to
voltage plot is almost linear with 2-3 % error and some
S-curve behavior.
Spindle sensor is 1000ppr optical
encoder, max speed is 2000 rpm, so max velocity is 133 333
pps.
First of all if motor is
not loaded I get max RPM at ~165 Vrms, also i have
noticed that applied voltage is not directly
proportional to RMP, actually not directly at all :)
Also at low speeds spindle can be just stopped by hand
(30 RPM).
I have to close the loop to operate at
CCS and for threading.
So the questions is:
Can this setup operate in closed loop
mode using KFLOP step dir chanel closed loop PID and
filters? Or i should make come C
program to drive my controller? Also is selected
velocity control method is ok or I should change my
controller software to be driven from PWM or something ?
Thx. in advance
B.R. Danchik
